Posted 17 Jun 2016 (edited) Hello everyone, I hope you are all doing very great, I'm new to Schneider PLCs and I have a project that I need to work on, so I will need your help with the following issues: *) How can one determine which Schneider PLC series is used if you only have a fuzzy picture of the PLC ? *) I need to setup a historic of alarms, I have 13 PLCs, no connexion between them... I was thinking about creating a connexion between those PLCs and a database, so I need your help to determine a list of ALL the materials i will need (from cables to servers to a computer if necessary...) and some documentation on how that can be done... Thank you so much for helping me, Best regards Edited 17 Jun 2016 by mohammed.cgf Add image Share this post Link to post Share on other sites
Posted 27 Jun 2016 That is a tsx micro pl7. You use pl7 pro software to connect to them. To connect all these plc on a network I would suggest getting a tsx etg gateway to convert the connection to ethernet. The database and pc side it up your discretion. Either get a scada package to retrieve the data from the plc or you must use an opc server to collect the data and write it to a db Share this post Link to post Share on other sites
