deuslupos
omron cj1m cpu11 analog programming/designer
3 posts in this topic
hey!
I'm pretty new to PLC's, and I'm supposed to ''teach'' the people at my internship how this PLC works, but I have encountered a problem.
I've gotten pretty far with all the digital programming and understanding how everything works, but I just can't figure out how the analog inputs/outputs and programming works...... I've had a fair explaination on PID and how this works. I've searched the web as well to figure out what PLC instructions to use.
I hope you can answer my following questions.
1, what are the most used PLC instruction blocks which I can use for temperature control, and how am I supposed to use them?
2, Could you please give me an example on how to use PID and what numbers will I need for the calculations?
3, what are the most used PLC Instruction blocks (apart form the analog ones) that I should include in my tutorial?
this is my setup:
Ethernet switch
MOXA EDS-205
Plc voeding
PA202
PLC CPU
CJ1MCPU11-ETN
Digital IN (16x)
CJ1W-ID211 (SL)
Digital IN (16x)
CJ1W-ID211 (SL)
Analog IN (8x)
CJ1W-AD081 (SL)
Analog IN (8x)
CJ1W-AD081 (SL)
TRANS OUT (16x)
CJ1W-OD212 (SL)
TRANS OUT (16x)
CJ1W-OD212 (SL)
Analog OUT (4x)
CJ1W-DA041 (SL)
thank you soo much for looking at my question and considering helping me! the OMRON helpdesk hasn't been very helpfull.
kind regards,
Deuslupos,
For internal temperature / process control, you might use the PID or PIDAT instructions as well as the TPO instruction (if you have a digital output to control the heater).  You should also look at scaling instructions for the analog I/O (APR, SCL, SCL2, etc.).   You might look at function blocks a bit for scaling as well, here is a good one that I wrote a while back:
http://forums.mrplc.com/index.php?/files/file/996-analog-scaling-function-block/
As far as PID is concerned, look around a bit, here is a good link:
http://forums.mrplc.com/index.php?/topic/7168-sample-pid-program/
2 people like this
