drusso
Ethernet and Power in 1 Connector
11 posts in this topic
Looking to install an HMI with an E STOP in a Stainless steel enclosure mounted permanently
The PLC is mounted to a portable machine that will be rolled away for maintenance.
Looking for a quick disconnect with ethernet and a couple of pins we can use for 24vdc and an Estop.
Has anybody found as clean solution using only1 connector?
thanks
Typically power and communications will be 2 different plugs.  I've never seen one with Ethernet and extra signals.  Maybe you can get something like a MIL connector and solder it up yourself with the right signals.
There is a standard.   You might try adopting the POE pinout.
Power over Ethernet
Power over Ethernet
POE isn't 24VDC.  Not from what I've read.
I was just saying it wouldn't be a bad idea to adopt the pinout for his application.
But then if a POE device is connected and those pins get 48V, that would be bad...
Grace makes plugs that can be mounted on a panel, and I love their products.  But it's not a cable, it's an access point.
So which connector did you choose?:shrug:
The connector is module so it was multiple part numbers.
09140082733 - 8 pin female
09140082633 - 8 pin male
09140014721  - ethernet female end
 09454001560 -  ethernet male end
09300100527 - hood
