Posted 4 May 2016 Using a Panelview Plus 7 HMI with FT view Studio. Is it possible to enable/disable a button? I can't find anyting on the button 'Animations' menu or anywhere else. Thanks. Share this post Link to post Share on other sites
Posted 4 May 2016 I'm not sure if there is a direct approach. Method 1: Use the Visibility option on your button. Make a copy of it. Select one of them, then 'right click' and choose Convert To Wallpaper. Then position your functional button over the wallpaper button. When it disappears your non functional wallpaper button will be shown. Method 2: Code the Enable action in the PLC. Program a confirmation tag / address that will turn on when you want the button to animate (or be Enabled). Use this tag / address in the Indicator field of the Connections tab for your button. Share this post Link to post Share on other sites
Posted 8 May 2016 On 5/4/2016 at 10:00 PM, IO_Rack said: I'm not sure if there is a direct approach. Wow. Really?! Share this post Link to post Share on other sites
