Posted 19 Apr 2016 Hello Experts I am facing problem with CJ Series Analog I/O module MAD32. The Run LED is Lit, ERC Led is also Lit. what could be the reason? Share this post Link to post Share on other sites
Posted 19 Apr 2016 The ERC light normally indicates an open or out of range connection to a current loop device. Share this post Link to post Share on other sites
Posted 19 Apr 2016 Tahnk you Mendon Systems for the reply The two current inputs of the module are connected to analog output terminals of two indicators. The sticker on the indicators show that the analog output is 4-20mA. When the two inputs are connected, the HMI display for the analog signals becomes unstable (changes rapidly) Share this post Link to post Share on other sites
Posted 19 Apr 2016 I would suspect that the power supply to one (or both) indicators has become erratic. Share this post Link to post Share on other sites
Posted 19 Apr 2016 The power supply to the indicators is 220VAC, both are powered up and working correctly Share this post Link to post Share on other sites
Posted 19 Apr 2016 Obviously something is not working correctly. The ERC indicator on that module will come on whenever the voltage on an input set for 1-5vdc (or 4-20ma) is not in a range between 1 and 5 volts. The erratic readings you are seeing would indicate that there is something other than DC voltage on those input signals. Share this post Link to post Share on other sites
Posted 23 Apr 2016 Dear Sir I have set the all the input selector DIP switches for Voltage. In this condition the module should not detect a disconnection, right? Still the ERC indicator is Lit Share this post Link to post Share on other sites
Posted 23 Apr 2016 The ERC detecton works when any of the four ports is set to 1-5 volts (also 4-20ma). There is only one ERC indicator so an out of range condition on any one of the ports that is set to 1-5 volts will trip the indicator. The function of the Dip switch is to connect a 250 ohm load across the input terminals for current loop inputs. Opening the switch with a current input connected would probably cause an ERC condition. Read section 9 of the W345 manual. Share this post Link to post Share on other sites
