littledaus87
CP1E-N30DT with Hyperterminal PC
13 posts in this topic
Dear Expert,
i'm issue to do communication CP1E with PC via RS232.
im try to use plc for sending information and receive by hyperterminal pc.
after googling some information there have multiway to success. by the way until now cannot settle.
please expert share completed setup that's work:
1. communication cable from PLC - PC (my information use pin (2,3,9 jumper 4&5) - (2,3,5 jumper 7&8)
2. sample program that works (im using TXD & RXD with memory D1000 to keep data)
3. connection cable to PC using MOXA Serial to USB converter.
4. plc serial setting (default: 9600,7,N,1,Host link)
my target to give instruction to printer to start print. printer need ACSII code. if this communication success i'm will convert all data to ACSII by ACSII convert function.
thanks,
Your port must be set to RS232, not Host Link to use TXD and RXD.  Make change and cycle power.
You might also need a jumper between 4 and 6 on the PC end. Some PC's need it, others don't, but it can't hurt to add it.
Yes, I agree.
PC  PLC
2 - 2
3 - 3
5 - 9
Jump 4 to 5 on PLC side and Jump 4 to 6 and 7 to 8 on PC side.
On 3/18/2016 at 0:48 AM, Michael Walsh said:
Yes, I agree.
PC  PLC
2 - 2
3 - 3
5 - 9
Thank you Mendon & Michael for clear information.
Dear expert. thanks it works well.
one more question regarding this testing, how to clear memory after we send 1packet of data.?
example:
from plc send: JDU|A|B|C|D| in decimal 74688512465124661246712468124
after job done i'm need to clear memory and wait for other instruction otherwise previous memory will overlap with new instruction.
Use BSET instruction to block set #0000 to your packet area.
Thank you Anthony, its really works.
now i'm looking to learn new communication. because my project cannot using serial cable due to distance PC and PLC its about 100meters.
from our supplier they propose to use CP1L-EL20D-R, now i'm loan it to study/test ethernet/tcp. i'm searching knowledge about it.
can you screenshot the ladder diagram? i don't know how to create ladder diagram for rs232 communication.
thank you.
Open CQM1 in CX-Prrogrammer and change the PLC type to CP1E.
