Scadadoctor
[Demo Software] - SIEMENS S7-300/400 .NET PLC Driver for HMI/SCADA
1 post in this topic
View File
The Siemens S7 MPI driver works to exchange data between OPC clients and Siemens S7-300 and S7-400 PLCs using the MPI protocol. The MPI interface requires the use of the Siemens S7 MPI serial port adapter available from your Siemens dealer. The serial port MPI adapter allows it to communicate with Siemens S7-300 and S7-400 PLCs at either 19.2 KBaud or 38.4 KBaud. The driver talks directly to the MPI adapter cable without additional software packages or libraries.
Features
-Supports all Siemens PLC’s or any other device which uses ISO over TCP protocol.
-high-speed communication
-suitable for transferring medium-to-large data volumes (<=8192 bytes)
-routing capability (i.e. can be used in the WAN)
-package-oriented data transfer
-dynamic data lengths are possible
-Performance - 500mhz Pentium - 10 words: 15msecs - 100 words: 35msecs (av
-Level 4 of the ISO-OSI reference model
-Up to 16 nos. of possible connections per S7-300 CP
This driver can be conviniently used with Visual Studio in development of complete large scale complex HMI/SCADA Systems. It can be used to perform advanced reporting MES, analytics, IoT, Big data type apps. One example is available to download here
For More Info
Overview of Parijat Drivers: Click here
Additional supporting Info about Parijat Drivers:Click here
Complete Related Driver options: Click here
