Thenoobs
Monitor Data using fx3u.enet.l
8 posts in this topic
I use delphi to program and connect to fx3u-enet-l using actfxenettcp component. I can connect and retrieve data using readdeviceblock2 from the plc. The problem is, If i put the readdeviceblock2 in a loop to always monitor data, it only work for 1 or 2 minutes. Then the connection close. How to monitor data in real time using actfxenettcp?
Operational setting:
Communication data binary. Initial timing always wait for open. Send frame ethernet. Tcp existence use the ping.
Open setting:
Protocol tcp. Opensystem unpassive. Fixed buffer read. Procedure exist. Pairing open disabled. Existence no confirm.
I would say that there's a problem with your Delphi code, but there might be an error in MX Components of course.
Could you make a screenshot of your settings in FX-ConfiguratorEN, and a text file of a sample Delphi<->PLC program?
The code similar to this:
Actfxenettcp.cputype := 520;
Actfxenettcp.hostport := 1300;
Actfxenettcp.timeout := 5000;
Actfxenettcp.hostip := '192.168.0.2';
If Actfxenettcp.open = 0 then timer.enabled := true;
Ontimer: timer interval 500
Var a: smallint;
Begin
Actfxenettcp.readdeviceblock2('D300',1,a);
Label1.caption := a.tostring;
End;
Do you also have screenshots of the FX Configurator EN settings (all modified settings)?
First: Try setting FX ConfiguratorEN settings as per the image.
Second: in your Delphi code you should have a break in the timer in case the conncetion is unexpected closed again (cable failure or similar) so that the connection can be reestablished at a later point.
Third (if both the above fails): What happens if you increase the timer interval? Have you tried setting it to e.g. 5 seconds as a test?
I notice if I put 2 or more consecutive readdeviceblock  cause the error.
If I put delay between readdeviceblock, I can manage to reduce the amount of error.
this code gives error everytime
while 1 do
begin
readdeviceblock('X0',4,x[0]);
readdeviceblock('Y0',4,y[0]);
end;
this code gives error sometimes (not as much)
while 1 do
begin
delay(500);
delay(500);
end;
Did you set the comm params as in the picture?
What kind of error do you get?
