terminalcity
Low-speed Servo recommendation?
3 posts in this topic
Hello:
I'm looking for recommendations on a quiet low-speed servo motor/driver combination. The quiet part is important...
The application is a very lightly loaded indexing table. The motor drives a timing belt reduction chain, and takes very little torque to do so.
The motor has to :
- positionable over RS-232 or RS-422/485
- supply maximum of about 200RM. The low-speed and quiet performance is what is important.
- Run on a 24VDC driver or something close
- be direct drive (i.e. no gearhead-- too noisy)
I've tried an Animatics SM1720 series four motor, but since it is commutated by hall sensors it makes a real racket, squealing and squeaking below 50RPM or so.
I have seen options like the Vexta AlphaStep and and other similar drives, but I am very curious to know what a pro would spec for a low speed quiet drive.
I would be forever gratefeul for any advice!
Thanks
Daniel
Edited by terminalcity
If your linear travel speed is low, and most servos growl when you drive them in the dirt, why not add a gearbox to bring overall speed into the acceptable range?
Another consideration is a linear servo (sort of a pneumatic cylinder that is servo-driven).
https://www.festo.com/cms/nl-be_be/9802.htm
http://www.moog.com/products/actuators-servoactuators/industrial/electric/stard-electric-linear-servo-actuators/
IAI (Intelligent Actuators) has a product line that may work for you.  I integrated these some years ago to communicate RS-232 from a GE Rx3i PLC.  They work great when you need to go from known point to known point.  Not a lot of fun, though, if you need to adjust the position points on the fly or re-program the points (serial programming using their basic programming software).
http://www.intelligentactuator.com/part-search/
Have you tried running your Animatics motor in sine commutation rather than trap commutation?
Use "mds" instead of "mdt" and report back.
