Posted 5 Jan 2016 Clock_S90_PAC_QP+.zdrw View File Updated Clock logic and HMI screen simple and well documented. To use this, 'Import' this 'Toolchest' Drawer file into your PMC's Toolchest. Then 'Copy' one of the Ladder Blocks into your 90-30 or PAC Rx3i Target by holding down the Ctrl key while drag-n-dropping it onto the 'Program Blocks' in the Navigator window. The QuickPanel Screen along with the 'Indexed Message Grid' can similarly be brought into your QP or QP+ Target. If there is already variables in your project you may need to adjust some or all of those used here. The logic here also will help you to understand the Array_Move Function blocks in PME. Submitter RussB Submitted 01/05/16 Category PLC Sample Code Share this post Link to post Share on other sites
