KevanB
having issues adding modules to 1734-AENTR
4 posts in this topic
Client is wanting to use a 1734-AENTR with I/O and what not. When I go into the hardware tree to add I/O, its grayed out to add a new module to the hardware tree. JUST for this critter though, has anyone else experienced this?
Edited by KevanB
are you offline with the program?
If you are online with the program, you can not add a new module to the hardware tree.
I'm offline, I think I figured out though. with the 1734-AENTR you have to go into module properties and set the chasis size attatched to that AENTR within the hardware tree I guess. Never encountered something like that before. I couldnt add I/O to it because the chasis is defaulted to 1, which would mean the AENTR is taking that 1 slot up. Crazy stuff.
Just go to 1734-AENTR module properties, look for Module definition where there is a "Change..." button, click on it and select  a number in "Chassis size" according to the number of cards you are going to add (including the 1734-AENTR). Then, you were able to add cards by making right click on 1734-AENTR module.
