Posted 24 Dec 2015 hi i am using vijeo citect 7.4 i generate a report automatically using a triger but the report generated in the .rtf form which any body can change the values in the report so i want to either make the report in the read only form or convert it automatically to pdf + i ' ve another problem i am tring to write a string in the report using the form {tag_name:############} where the tag_name is a variable string memory where i store in it a word "starter" when the report is generated only two letters "st" is generated can any body give me a solution for these two problems , thanks in advance . Share this post Link to post Share on other sites
Posted 24 Dec 2015 not sure about second one but first one should be easy to solve. you can install PDF printer. all you need to do is print the reports to a PDF file(s). if needed, you can automate task using tools of your choice (for example AutoIt) Share this post Link to post Share on other sites
