Posted 20 Dec 2015 Has anybody used the Spectrum Controls 2080sc-IF4u analog module? This is a 4 channel analog module for the Micro800 series? I'm trying to set input 4 to (0-5v, x10(format)2-wire, 60HZ). I need someone to help me figure out the bit setting. This is what I have LSB=44 and MSB=44 could some else confirm this? Thanks Share this post Link to post Share on other sites
Posted 21 Dec 2015 Dec 44 => BIN 0010 1100 (bit 0, right) => (i) there is no filter for 1100; thus change to 1000; (ii) 0010 => is +/- 10V, but you state you are using a 0-5V signal, thus change to 0100. Try changing the configuration to 0100 0010 (Dec 66) Share this post Link to post Share on other sites
Posted 21 Dec 2015 (edited) That would give a 4hz filter. Try 01000100 ( Dec 68) for a 60hz filter. For the LSB Try 00000100 (Dec 4) For the MSB ( the 2 wire setting is for a RTD input it has no meaning for your 0-5v input) Edited 21 Dec 2015 by Mickey Share this post Link to post Share on other sites
