Posted 2 Sep 2015 (edited) Hello everyone! First of all, I'm a new comer to this forum from Indonesia. The name's Inno. Looking forward to share knowledge with all of you So I had this trivial, but annoying matter with CX-Supervisor Text Points. I had connected it to NJ101 controller. There I made a sample STRING, let's say "1234". I set this STRING to be stored in D0 memory, which means in ASCII it'll now contains : D0 = #3132 D1 = #3334 Then I use the Display Value (Text) Action to a Text Object in CX-Supervisor. The problem is, each Word on the Point display the LSByte first. So the resulting view in CX-Supervisor is : "2143", while I expect to see "1234" I know this can be easily solved by swapping the bytes inside the NJ program, but I'm curious, does CX-Supervisor has the feature to swap these bytes automatically? I mean, even NS or NB HMI can do so to accomodate Mitsubishi/others String system :D This occured for any Text type I choose (Signed/Unsigned/Raw Binary). Waiting for your suggestions Edited 2 Sep 2015 by innoaloe Share this post Link to post Share on other sites
Posted 3 Sep 2015 I didn't deal with NJ controller yet, only with C-Series (CJ1, CJ2, CS1) plc, and with there is no this kind of problem. Looks like they change it in NJ...Anyway, there is no function in CX-Supervisor as far as I know but in this case I would make a subroutine which does this rotating characters. there are scripts command you can use for this, like Mid, Left and Right, but I think the most easiest way is to do this in controller. regards Share this post Link to post Share on other sites
Posted 3 Sep 2015 Hi tashinz, thank you for replying. It might be so, due to the new programming standard used in NJ (IEC-601-something). I'm still curious though, because we still able to directly map a variable to C-Series memory area, as I stated above. Even doing data sharing between NJ and CJ2 won't cause these bytes to be inverted. It only occurs on CX-Supervisor. But I guess that's another issue. Share this post Link to post Share on other sites
