mhowasso
AB PanelView Plus
3 posts in this topic
Hi All, What is the difference between a PanelView Plus and the PanelView Plus 6..??? Thanks
Since you haven't gotten any other responses... As I understand it, AB switched up the hardware package between the two series. The PV+ can only run runtimes up to firmware revision 5.1, and the PV+6 runs v6 and up. You still use the same programming software, but you have to select the appropriate firmware revision when you compile the runtime.
Thanks Jeremy... I appreciate your help.
