kku
Updating Sysmac Studio
I downloaded the update file using the Omron AutoUpdate Utility. When I tried to install it I get a message saying 'Sysmac Studio is already in use'. Has anyone seen this before? I recently installed Sysmac Studio and this is the first time I am trying to update it. I currently have version 1.11. 15-04-2015 1-28-39 PM.bmp 15-04-2015 2-49-54 PM.bmp
If you are not running Sysmac Studio you should not get this error. Hit Ctrl-Alt-Delete, and if you see SysmacStudio.exe in the task list, terminate it. Then install your common components update (fine begins CMN), reboot, and install the rest.
I got RSNetWorx for Device Net problem "RSNetWorx Application has stopped working A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." I tried to reinstall it, but it couldn't help. If anyone got the same problem before and how to solve this issue? Thanks a lot!
Wrong forum. That is Rockwell product.
Michael need some help with sysmac update v1.17
please see attachement.
Try to install only the common components update.  Then try again to do full upgrade.  You can check and uncheck the items to be installed from that window.
