Posted 27 Mar 2015 Hello. This is the first time I use Ethernet in PLCs. I want to connect a Compactlogix L24 with remote I/Os and Panelview. I have many questions . But can you help me select the type of cable for this application , 2 or 4 pairs? shielded or unshielded? Share this post Link to post Share on other sites
Posted 28 Mar 2015 (edited) Man, that question is bound to get you 20 different answers. Personally I would say that it depends on the enviroment that you are installing your equipment in. If I am going to be running the cable through tough enviroments, be it possible physical damage, through bad enviroment, or areas that may have a lot of EMF/EMI due to High Voltage lines or VFD cable running near by, then I would use something like this: http://www.lappusa.com/5615description.htm When you go to this link, push the product finder drop down and choose "Etherline" and you can see the full line of product choises. I would terminate both ends of this larger than normal cable onto something like this at each end: https://www.phoenixc...&pdflanguage=en Make sure you get a proper "Punch Down Tool" to land the wires on these patch panels. Or they also make some that have screw lugs instead of punch down. Then just use preassembled patch cables from these punchdown blocks to the Plc/HMI/Switch/etc. If you are making your own patch cords or if you are not running your cable in a bad enviroment and want to just use a standard Cat5 or Cat5e cable then I usually use these to terminate on the end of this type of cable. http://www.platinumt...ucts/100003.php You will need to get the correct crimper, and you can get these in metal (to ground one side if you use "e" cable or the stadard plastic type RJ45 connectors. Others will have their favorites that they use which may work equally as good or better for your application. I am on ship so we tend to TRY and make things pretty bullet proof. BCS Edited 28 Mar 2015 by Bering C Sparky Share this post Link to post Share on other sites
Posted 30 Mar 2015 OK. I did learn with your Info. Thank you for your time. Share this post Link to post Share on other sites
Posted 30 Mar 2015 (edited) The cables and parts mentioned above are great. However, standard cat 6 cable run in conduit, or inside of Teck cable will work fine in most circumstances. Use shielded when you're running it in MCCs. Standard RJ45 connectors work as well, although there is one industrial RJ45 from Pheonix Contact I like to use. They are $15 each though, while standard RJ45s are $0.10-0.50 each, so it depends on customer requirements. Edited 30 Mar 2015 by MrAutomation Share this post Link to post Share on other sites
Posted 31 Mar 2015 I too would suggest a good quality cable like the LAPP, we currently use most any of the Belden 79XX series. Good cable with ready stocked here in the US. Share this post Link to post Share on other sites
