Posted 20 Mar 2015 Hi friends, In genie substitutions For example, in a genie%Tag%_MaxValue, %Tag%_MinValue, %Tag%_PV, are done for subsitution of %Tag% with TIT_101as TIT_101_MaxValue,TIT_101_MinValue, TIT_101_PV . In this example, when the genie is pasted, we give TT_101 as the genie's argument. However, if sTag is a string variable, that can take multiple values, -say TIT_101, TIT_102, TIT_103 I find it does not work. When I try using sTag in the genie, %sTag%_XXX it is not getting accepted. So also referencing the prefix as "%sTag%"_XXX is again useless. What is needed to substitute %Tag% by the value of a string variable? so that the tag name referenced is correctly calculated by concatenation of the prefix? Regards, Share this post Link to post Share on other sites
Posted 20 Mar 2015 Get in touch with Citect support - they are very good - I use them regularly. Share this post Link to post Share on other sites
