JanHrust
How to connect L-series PLC to Ethernet ST-Lite units
2 posts in this topic
Good day I have a scenario where I need to connect to Ethernet ST-lite units to an L-series PLC. With a Q-series you will use the Modbus card and create a Intellgent Function Module to do this and specify the header addressing for the unit. With the L-series, you have Modbus on the build-in Ethernet port, but how do I now setup and specify the addressing for the for the ST-lite unit? Please help...
Okay. Got it going. Basically you will use the Modbus Client Program of Mitsubishi, but with some changes. Attached is the standard Modbus FB and program with a basic step by step to set it up. Configuration.zip
