Posted 24 Feb 2015 I have read that it is possible, in CXDesigner, to download the program from the computer onto a memory card, and then download from the memory card into the HMI terminal. Is a similar thing possible with CXProgrammer, and PLCs? It would be quite useful, for the purposes of updating the program on a customer PLC that is located overseas, when the customer does not own a laptop with CXProgrammer installed. Share this post Link to post Share on other sites
Posted 24 Feb 2015 On most Omron PLCs it is possible. It is usually performed by turning on a specific DIP switch then cycling the power. Search your PLC manual for Memory Card operations or post back with a PLC part number. 1 person likes this Share this post Link to post Share on other sites
Posted 25 Feb 2015 Thank you Mr Rack. My PLC part number is CPM1A-30CDT1-D-V1 NL. Share this post Link to post Share on other sites
Posted 25 Feb 2015 I have done it with CJ1, but only to download program without symbols, comments etc., although as I understand from manuals, it should be possible to download it. In CX-Programmer you select download to file, and you name a file REPLACE.OBJ. Copy this file to CF Card, put it to CJ1 CF Card slot, turn on DIP switch 2 to ON, switch power supply off the on, and the program should be loaded. I am afraid it is not possible on CPM1A models, since they do not have CF Card slots. 1 person likes this Share this post Link to post Share on other sites
Posted 20 Mar 2015 Follow this guide for CJ1/CJ2 CF card backup/restore... Mind this is not an official Omron document, I put it together to send to customers. PLC Compact flash backup&restore guide.pdf 1 person likes this Share this post Link to post Share on other sites
Posted 29 Jun 2016 On 3/20/2015 at 3:14 AM, PdL said: Follow this guide for CJ1/CJ2 CF card backup/restore... Mind this is not an official Omron document, I put it together to send to customers. PLC Compact flash backup&restore guide.pdf What guide? Where is the link to this doc? Share this post Link to post Share on other sites
Posted 29 Jun 2016 Hi, I think that after the forum upgrade the attachment got lost... Here it is. CJ2 PLC Compact flash easy backup&restore guide.pdf Share this post Link to post Share on other sites
