Ken Roach
Crimson 3 Timestamp String
13 posts in this topic
I'm posting this Red Lion Crimson 3 application here as a reminder and repository for sample code. This Forum seems to be a favored place to put sample code and sample applications. I think Red Lion should undertake a Forum of their own, especially because of the relatively steep learning curve for their C-like Program language, but for now this will have to do. I have an application where I am manually creating descriptive text strings for events that are being monitored by a Data Station Plus. I want to have a tidy String that contains the Year, Month, Day, Hour, Minute and Second to go into those descriptive strings. While this is easy to do with display objects because there is a Time and Date Primitive, this method works for making strings that will be used with the file I/O commands. This program is configured to execute "On Tick", so it runs every 1 second. The result is a text string in the format "02/01/2003 08:53:46" This was written for and tested on a Data Station Plus DSPSX000, using Crimson 3 version 579.003. Timestamp_String.zip
Ken check out this function library. http://www.theautomationstore.com/red-lion-crimson-3-0-function-library/ It was originally provided by Red Lion in C2 format but I still use many of the programs in it today.
Holy crow, that's terrific ! Is this on Red Lion's website someplace, or did you just have to ask for it ? While their Reference manual is *okay*, the Red Lion programming language has a pretty steep learning curve for your average controls programmer. If you have a background in C, obviously it's a lot easier because so much of the syntax is similar.
Dan was helping me develop some of my first custom remote monitoring code back in 2009 and gave it to me then. It has been very useful over the years but I've never seen it posted anywhere else. The G3 is capable of so much, but that can turn into a limitation very quickly because of lack of sample code. I've started working on posting sample code of various projects I've done. One reason is I've finally hit the point where I can't remember every project I've done so I need a way to store samples for later use. I figured I would store it on the web where it may help others and they may decide to share some of their samples as well. For example this one is on interfacing a G310 with a Honeywell DC2500 which took me about 6 hours to workout. It was a bear to map out, mainly because of lack of documentation by Honeywell. http://www.theautomationstore.com/red-lion-g310-to-a-honeywell-dc2500-temperature-controller-sample-program/
I concur with Ken about the separate forum for the Crimson stuff. Their Dataloggers and RTU's are becoming more prevalent in my line of work also. The forum has rescued me several times trying to figure out how-to. The Red Lion site, last time it looked, was mostly version 2 examples.
Any hope of a separate forum for the Red Lion stuff?
BUMP?
Teaser! :)
Bump again!!!
I forgot completely about this thread until I revisited it today, 4 years later, when I was having trouble figuring out some serial port commands on a DataStation Plus.
Neat !
Neat !
Hi Ken. The Crimson 3.0 function library referred to in this thread does not seem to be available on line. Any idea where i can get a copy?
Gareth can you post what your are trying to do. I may have some code that I can provide.
Hi jazzplayermark. I want to be able to parse a text string. The sting has data fields containing numbers or text and may have one of the following formats
"%s %d"
"%s %s"
I am using the Crimson Find() functions  to find the location of the space character and then splitting the string into two substrings
        index = Find(message,32,0); // find position of space
        tok1 = Left(message, index);
        tok2 = Right(message, Len(message)-index-1);
I'd like to use  TextToInt to convert tok2 to an Int if it is an Int but need to test first whether it is a number or a string
Any suggestions would be appreciated
