derekp
Micrologix 1400 High Speed Counter
3 posts in this topic
Micrologix 1400 HSC:0 Looking for a configuration example. Using a gas meter with a contact output representing x pulses per cubic foot of gas. Want to calculate flow rate and totalize. Edited by derekp
Lot of good information in this old post: http://forums.mrplc.com/index.php?showtopic=12749 If you still have questions, post again. I don't have time right now to draft a lengthy response, but I have done something similar. You need to wire the pulse output of the meter to one of several specific inputs on the ML1400. Which one depends on which counter you will be using. Then you'll need to configure the high-speed counter (HSC) in the function file. Pretty much all you should have to set is the Mode and the Enable.
Here's a video I made on configuring the Micrologix 1400 high speed counter. https://www.youtube.com/watch?v=1eDmN_tvXb4
