ShararehMirbagheri
Megalis HMIGTO5310 IP Address
Cycle the power on the screen. Then rapidly press the top left and bottom right corners( 1st the one then the other). Two corners are the default so if the programmer didnt change it this will work. If you did this correctly in will go into the config before the runtime loads
It does work. Check the help file for exact instructions. I did this yesterday with a "two corner" screen. It depends how the screen was programmed with the original program. Ps. Do you have the original program in Vijeo designer?
Is it a new panel?? Then it should come up a startup page where you can press network to go to adress settings.
