Posted 19 Aug 2014 How to know what is my Megelis IP address? Share this post Link to post Share on other sites
Posted 24 Aug 2014 Cycle the power on the screen. Then rapidly press the top left and bottom right corners( 1st the one then the other). Two corners are the default so if the programmer didnt change it this will work. If you did this correctly in will go into the config before the runtime loads Share this post Link to post Share on other sites
Posted 25 Aug 2014 I had the same problem it didn't work!! Share this post Link to post Share on other sites
Posted 27 Aug 2014 It does work. Check the help file for exact instructions. I did this yesterday with a "two corner" screen. It depends how the screen was programmed with the original program. Ps. Do you have the original program in Vijeo designer? Share this post Link to post Share on other sites
Posted 27 Aug 2014 There is no Program on it. even when the bought it . Share this post Link to post Share on other sites
Posted 28 Aug 2014 Is it a new panel?? Then it should come up a startup page where you can press network to go to adress settings. Share this post Link to post Share on other sites
