raulvirtudazo
MVI94_MCM
2 posts in this topic
Hello Guy, Hi i need your help i have MVI94_MCM has already installed. The existing configuration is Start Read_Data is 700 and the Read_data count is 42 this configuration is working well. Then i edit Read_Data count into 150 then i download it was successful. I create a copy file in the controllogix Read_Data[50] why there no data comming from this address but in the prosoft module there is. Thank you so much......
Changing the count will change the number of blocks required to pass the entire input/output image. Since you changed the count to 150, you will need to edit your LIM statements accordingly. A block can only pass 8 INTS at a time, so take your number (150) and divide it by 8.. this equals 18.75.. now round it to 19. So... in your LIM statements, change the high limit to 19. That should get you on the right track. If you have further issues, I suggest you contact ProSoft: support@psft.com
