Posted 10 Dec 2013 (edited) Hello everybody, I'm trying to set a C-More HMI with a MicroLogix 1000 but I'm having lot of problems creating the tags; In the first Rung of my code I have a pushbutton to turn on a pump with a holding contact or latch, then i have the output to the pump. My problems start when I try to asign the address from the MicroLogix to the C_More HMI. Here's what I'm trying to do, Tag Name= Pump Start Device name= DEV001 Tag Data Type= Discrete PLC Address ( MicroLogix 1000 ) Memory Type= B Address= B3:0/0 Bit=0 When I click ADD I get this error "Error GUI-024 : Invalid Address. According to this my problem is the addressing between the MicroLogix and the C_More HMI. Any help will be greatly appreciated. Edited 10 Dec 2013 by RobertL Share this post Link to post Share on other sites
Posted 11 Dec 2013 (edited) PLC Address ( MicroLogix 1000 ) Memory Type= B Address= B3:0/0 <- Remove the "/0" - this part is just for the word. The next part selects the bit. Bit=0 Edited 11 Dec 2013 by b_carlton Share this post Link to post Share on other sites
Posted 11 Dec 2013 (edited) Robert, I've used C-Mores with several ML1100. Checking a recent project, I find the following for tagging: Tag Information: Device Name: ML1100 ( I changed mine from default of DEV001) Tag Name: PB_SYS_START Rest of Tag Info is greyed out, but does indicate Tag Data Type as Discrete PLC Address: Memory Type: B Address: 3:4 Bit: 0 Edited 11 Dec 2013 by pcmccartney1 Share this post Link to post Share on other sites
