Posted 17 Mar 2013 Hi all, I need to work with a 90 series micro fanuc plc. What software do you think would work overall most widespread for me to get? If I plan on connecting to the 90-30's micros, and the AID16D series cards (sry i do not know what series this card is out of) Can anyone inform me? I know the Logicmaster 90 is old but for the micro is this the only option? I have heard versa pro is has compatibility issues. I would be using windows 7 or XP. I work with AB mostly, and do fanuc machine controls as in PMC work, which I use Fladder. And am also in need of an upgraded version of Fladder also since I just ran into a PMC-N and i cannot compile this from my SRAM card into Fladder for some reason the Fladder does not support this PMC type.?? Any information would be appreciated. Thank you! Bill Share this post Link to post Share on other sites
Posted 17 Mar 2013 (edited) Get Proficy Machine Edition Micro/Nano Development software for the PLC, for FAPT Ladder you will need to go to Fanuc USA as GE and Fanuc have split ways. Also: The Series 90 Micro Manual is here.http://support.ge-ip.com/support/ind...nel&id=S:DO881 If you get Proficy ME you may need this too: http://support.ge-ip...cale=en_US Click Downloads > Firmware Update and Search on S90 and get firmware version 3.10 which is a must for Proficy ME. The "Cheater" cable here will work with it. http://forums.ge-ip.com/showthread.p...0395#post60395 Edited 17 Mar 2013 by RussB Share this post Link to post Share on other sites
