Posted 12 Feb 2013 Aloha, I have been noticing in my RSLinx RSWho window that some of my SLC icons are changing. In past, the SLC's on the network would show the IP address and Device Type as SLC-5/05 and then the Online Name would be the Processor name. Lately, I have been noticing some of the processors are showing up with a weird icon with online name as the processor model number. See below attached image. Anyone know what is going on? Thanks so much. Grant Matsushige Instrumentation Specialist Canada-France-Hawaii Telescope Corporation Share this post Link to post Share on other sites
Posted 12 Feb 2013 Would you by any chance be in process of upgrading SLC to Control or Compact Logix. The icon you have highlighted is the ControlLogix icon IIRC. Share this post Link to post Share on other sites
Posted 12 Feb 2013 No, no Control or Compact Logix. We've been running SLC's other than just that one Micrologix unit for years and years. Only recently have I seen that new icon show up and it's been happening over time, one by one. Share this post Link to post Share on other sites
Posted 12 Feb 2013 I suspect it's an EDS registration issue. You'll see that all of the devices with Product Names instead of Program Names are Series C FRN10. That's not new by any means, but it might be newer than the other controllers on the network. When RSLinx Classic browses a network, it requests the Identity Object from each device it discovers. If the Identity Object codes (Vendor, Type Code, Product Code, Firmware Revision, Product Name String) match an EDS that's in the Registry, RSLinx can check with the EDS and show the correct icon. When RSLinx encounters a device without an EDS it recognizes, it will make an educated guess. It knows it used the ControlLogix protocol (EtherNet/IP) so it's a safe bet to show a 1756 series module icon. In fact, ControlLogix and CompactLogix devices will be labeled "1756 module" in this case. I suspect that because RSLinx doesn't recognize the SLC-5/05 controller, it just shows the string that it read from the "Product Name" string. Since it doesn't know that the device is an SLC-5/05, it doesn't know how to query the SLC for its Program Name. Program Names are not, as far as I know, part of the Identity Object. Try downloading and registering the EDS file for this model of SLC-5/05 and see if it changes the browse behavior of RSLinx Classic. Share this post Link to post Share on other sites
Posted 13 Feb 2013 (edited) Ken, it looks like those in particular appear as if being viewed under the Ethernet/IP driver. Could it do that by having the IP addresses in the browse list appended with ":EIP"? Edited 13 Feb 2013 by OkiePC Share this post Link to post Share on other sites
Posted 23 Oct 2019 (edited) Hello! Did you solve the problem? I have the same problem. Edited 23 Oct 2019 by Dung25009 Share this post Link to post Share on other sites
Posted 18 May 2020 Hello all - I just upgraded 11 SLC 5/04's to 5/05's and witnessed the issue with the Device name. I noticed that all Ethernet-based devices show product ID in the "Online Name" column. You don't see the device name unless you expand the backplane to the CPU. I need the device name so I can update the new SLC's with the clock tool. I was able to get it to work by adding the 5/05's IP addresses to the older ETH driver. Now the names show up and I can map then through the clock tool. Unfortunately, the Online Name is "1747L552" for all of the 5/05's in the clock tool - it appends (X) for each SLC. Now all of my SLC's are updated. Best, Chris Roland Share this post Link to post Share on other sites
Posted 18 May 2020 (edited) Click Communication - Configure Drivers - Select Ethernet Devices, Add new. Enter a name like Job number, Machine project #, then enter IP address for that PLC Also did you check the processor name for uniqueness? Edited 18 May 2020 by BachPhi edit Share this post Link to post Share on other sites
