universe
PL72 On Windows XP
Hello all, First I'd like to thank your for this forum, then I have a TSX17 2X PLC that I need to backup the programme inside and make some changes as some outputs seems damaged, so I tried two options and both failed, the first is with Automgen trial that made me able to connect but I have only one way connection (PC->PLC) while I need both (PC<=>PLC) , the second is with PL72 on Virtual PC 2007 and FreeDOS, that I managed to install by myself and I don't know if I did the right choice, and everytime I type pl72.pif or pl72 to start the PL72 software I get the "command not found" error message, despite I edited the pl72.pif with the right paths. So I kindly ask if there is another way to communicate with TSX17 2X? Any help will be much appreciated. Thanks in advance. Edited by universe
Hello, Well, now I am running PL72 under Virtual PC 2007 and MS-DOS7.1 but when I start the application is tells me "No Active Drivers!", does someone have any idea about this? Thanks in advance for any hint.
After some researches I discovered that the file DUNTLW01.SYS is missed which is for unitelway driver, but I have DTSXPC.SYS from the name it's a "Driver TSX PC", can't this do the stuff? Edited by universe
Hello again, I loaded the driver with config.sys and now I get the error "Driver Initialization Error" everytime I try to connect the PLC, any ideas? Thanks in advance.
