ones_and_zeros
Converting Integer Files To Strings?
3 posts in this topic
I'm currently working on a communications project. I made a string in RSLogix 500 and moved it into an integer file. I then messaged this integer file to an RSLogix 5000 program. Is there any way I can convert this integer file back to a string in 5000?
Have a look at the DTOS Instruction. Stu....
the data in the integer file that you sent to the CLX5K was it in raw string data? IF String data RS Logix 5000 String format is a UDT MyStr.Len and MyStr.data Use COP to load the MyStr.data from the RSLogix500 Data then correct the MyStr.Len with your known length eg COP MyIntArrray[0], MyStr.Data[0] ,10 //* copies 10 characters then MOV 10, MyStr.Len // *corrects the string length
