ahuat
CQM1H network
32 posts in this topic
i have made some modification on the test2.cxp
No, it will remain as Hostlink, even though you are changing physical ports. You need to post test2.cxp as a file.
Here's the file, i use CX Programmer Ver 4.03 test2.cxp
You had some problems with the conversion for FCS and TXD. They are different in CJ1M. Also use A392.05 and A392.06. See changes to DM0 and DM1. They are needed for the FCS instruction. Remember that when CQM1 uses BCD for data format, CJ1M usually uses HEX for data format. test3.cxp
Finally!!! Now it works!!!! Thanks a LOT Mr. Anthony, it is ok if i send you my code later if already more complete? Hoping you all the best
Please post your final code for all to see. This is why MrPLC.com works!
Ok, i am still waiting for 2 sets of CQM1H-CIF12, after i received it, i will try to make a "polling" for 1 machine first. Thank you
