Emach
Wall Clock questions V19 on CLX
A not so simple question for you all. I have a machine that routinely runs for 300 hours. Previous versions of the machine, running SLC's, simply accumulated time using a 60 second timer and used CTD's to tick down the remaining hours and minutes. How bad can the time drift when using this same scheme on a CLX -L32E processor? If the time drift is relatively high, I am looking for some advice on how to calculate the completion time... Should I just convert my cycle time to microseconds and add it to the current value at the start of cycle? That way I could just use a GEQ command to stop the cycle... I'm also thinking I need to use the clock utility to sync the PLC back to the network. This would be really handy when the power drops out.
I'm not sure I follow this one. The L35Es keep time when the power is off. Still nice to keep all the clocks in sync, but they shouldn't be getting that far off normally.
Check TConnolly's totalizer solution in post #9 of topic 109702.
