cowboy_glb
E1101 touch panel can not display
hi everybody I have five machine ,PLC IS Q06H,touch panel is E1101,last night ,one touch panel can not display drawing,it is faint light,24V power is normal.can you give me root cause and repair method,thank you
Sound like a hardware fault, you should contact your local distributor...
download software to terminal,the issue be solved. Edited by cowboy_glb
Dear, Please follow the step given below 1>Power OFF the HMI and remove HMI battery. 2>Power ON the HMI and Check the display screen If screen is still not getting then that's hardware problem.
