dr_sjajko
CQM1H-CPU21 connection to PC 100 meters distance
5 posts in this topic
Hello to everyone. Can someone help me? How to connecting peripheral port Omron PLC CQM1H-CPU21 with a PC at a distance of 100 meters. Now I have a cable connection CS1W-226 but it's a small distance. Host Link Port is busy with my NT21 panel Thank in advance.
Too far for serial. You may get away with RS232/422 converters - 4 wire not 2.
Thank Bobb Can I use CPM2-CIF11 side CQM1H-CPU21 PLC (peripheral port) NT-AL001 at PC side, the HOST LINK to communications.. Is this the correct option. If anyone has experience I prayed for help. thank in advance Edited by dr_sjajko
I use the Adam converters from Advantech.
Thank Bobb I got a connection with two converter RS232/485 and RS232 crossed cable on the peripheral port side CQM1H-CPU21 I used the converter that I have done a serve me for programming Siemens S7 200 PLC, can be used and other RS232/485 converters. If anyone has similar problems as I continue with a scheme that was making my tested and works Omron_RS232_485 _peripheral_port.pdf Edited by dr_sjajko
