Posted 30 Nov 2009 Hello, Just wondering if anyone could recommend an adhesive-backed mounting pad that actually holds and doesn't fall off 3 months after installation. Thanks very much, plcdp Share this post Link to post Share on other sites
Posted 30 Nov 2009 Try a small drop of superglue on the adhesive before mounting. Share this post Link to post Share on other sites
Posted 30 Nov 2009 (edited) I recommend a silicon based adhesive, similar to what is used to hold a rear-view mirror to a windshield. It is best for temperature changes, if the problem is a chemical reaction of some sort due to the process you may need to research those reactions. Of course with all adhesives one must follow directions, i.e. "clean dry surfaces". If there is a thin film of cutting oil on the back panel, not much will stick very well. However, nothing will beat a self tapping screw or similar. Edited 30 Nov 2009 by RussB Share this post Link to post Share on other sites
Posted 30 Nov 2009 We usually use them on stainless panels and when we put them on we will put some 5-minute epoxy on the corners. That seems to hold up the best for us. Share this post Link to post Share on other sites
