ronsecrist
Omron Ethernet/IP to Allen-Bradley Ethernet/IP
30 posts in this topic
On 2/2/2016 at 9:39 AM, Crossbow said:
Edit your tag sets on the CJ in Network Configurator.  You need to use the Advanced button at the bottom of your tag set window on the CJ and set the proper instance
HI Linutux
Can you send your screen shot ? how you did this ?  i am also trying to do the same , i am new to omron . can you please send screen shot of your step number 1( or what needs to do at omron side to make it run) at omron side we have
ITEM PLC
REGISTER
DATA
TYPE
1 D1000 32-BIT ASCII
 , step no 2 and 3 are very clear at AB side (adding a generic module )  .
Thanks in advance  waiting for your reply.
Hello Everyone,
I am new to this thread.
I have CX-ONE and I have configured my Omron CJ2M CPU35 PLC to work over EIP. So i have configured the Ethernet/IP port and assigned an IP address.
Now I want to read/write the values from Omron PLC for addresses in DM memory area. Anyone can help here with the request format or telegram structure to read / write the values from omron PLC ?
Here is the link that was broken some time ago. It is for EIP communication with an Allen Bradley PLC. You did not mention what you need to communicate with. If it is not AB then you should start a new thread.
Hello !!!
Undertake CPU CJ1M (Omron) with a PanelView Plus 7 (Rockwell).
Naulation (runtime), communication starts, and data is sent and received as information.
When I download an HMI, the "DETECTED SHORTCUT" alarm appears.
Someone to help me?
Edited by Jay Anthony
Translation
This is exactly how it looks for modern stuff. Sysmac Studio + NX1 + Compact Logix. 100 bytes in and out.
