ziadsaka
incremental encoder
how could I find out the direction of rotation in an encoder connected to plc,need example program
1'st draw the channels 'pulses' cahannel A above and Channel B under it as 90 deg offset. 2n'd go from left to right and when B goes up take one-shot for it. If Channel A is true, you are going to fwd. then go from right to left and when B goes up take one-shot for it. If Channel A is false, you are going to rev. Now you have one shot/pulse for both direction. Think more! You can do 2 shots/pulse and you can do 4 shots/pulse-cycle indeed for both direction. So if you have encoder f.e. 20 impulses/round, you can get 80 shots/round and you have 4 times preciser resolution !
However if you have this encoder connected to a card supporting incremental encoders then this is usually done for you by hardware.
Usually Counter-units are 'expencive'. If you don't have any need for fast counting, use digital Inputs and save your money. Edited by Seppo Alanen
So please explain what you mean by "fast counting" or how to find out if counting is fast. <>
