Posted 22 May 2009 Looking for links to some simple SCADA What I need is a Scada Package or HMI package or some sort of OPC visualization to allow maybe max of 100 Points this needs to be ideally Freeware. or very cheap ware. Need to be able to communicate with OPC Server or Allen Bradley Controlllogix THis will only e used to display some PLC data for inhouse testing. I did try WINLOG LITE but it times out after about 10 mins - other wise it would have been perfect. We have full blown Wonderware for the main systems. but this means installing wonderware and servers etc I'm looking for something simple just to develop a few simple test tools graphics will be simple a few button and lights with some analog values. No need for security etc. ideally easy to set up on different machines in about 10 mins Share this post Link to post Share on other sites
Posted 22 May 2009 (edited) Hi, PeakHMI might work for you. Edited 18 Nov 2017 by Mark- Share this post Link to post Share on other sites
Posted 22 May 2009 A couple of other sources. http://www.plctalk.net/qanda/showthread.ph...ighlight=archie http://www.sielcosistemi.com/en/download/p...inlog_lite.html Share this post Link to post Share on other sites
Posted 25 May 2009 (edited) The free 2 hour demo of FactoryPMI should work great for in house testing and visualization. You don't have any tag or screen limits, but you do need to "reset" it after 2 hours of continuous use (10 second process). It will install and run fine on a desktop PC, and the application can be launched on any machine with Java installed across the network with a web browser. I recommend installing it on the same machine as your OPC Server (RSLinx/Kepware/Matrikon/etc), although you don't have to. Download here if interested. Edited 25 May 2009 by Nathan Share this post Link to post Share on other sites
Posted 26 May 2009 If you know any .Net coding you can by any OPC Client development toolkit for under $1000 US and make all the test applications you want Kepware makes ClientAce. CleintAce has a tool called the DA Junction that allows you to place objects in a Window and link the values from an OPC Server tag to the value fields of the objects. No coding is required for this it is basically drag and drop. You do have to have a full copy of VS 2003 or higher for ClientAce. Fred Loveless Kepware Technologies http://www.kepware.com Share this post Link to post Share on other sites
Posted 27 May 2009 (edited) Are you sure Express Edition won't work? Edited 27 May 2009 by Nathan Share this post Link to post Share on other sites
Posted 29 May 2009 You could try to download a free one from the link below: http://members.shaw.ca/xMasterHMI/xMaster Share this post Link to post Share on other sites
Posted 1 Jun 2009 Andyhill, InduSoft has a package that fits what you are looking for: 1. A 150 tag count license that is priced very well. 2. Can communicate to Controllogix without any additional cost. InduSoft has a built in driver for Controllogix (Ethernet/IP), and unless you need OPC for some other device, you would not need the additional OPC server. If you did need it, InduSoft can easily import tags from the OPC server, no need to re-type. (Saving you further time!) 3. Your main systems are WonderWare, (I am assuming InTouch), InduSoft can communicate back to WonderWare in several ways (if necessary). 4. InduSoft is quick and easy to install, and can easily be remotely administered, at no additional cost. An InduSoft trial version can be downloaded here: www.indusoft.com Some items to consider: If you use a free (or extremely cheap) package, will they be around when you need support? Where does the support for a free product come from? Good luck in your product search! Cheers. Skortier, InduSoft Share this post Link to post Share on other sites
Posted 15 Jun 2009 http://pvbrowser.org is an open source HMI / SCADA system. It supports OPC XML-DA but it can also talk Ethernet/IP directly. Share this post Link to post Share on other sites
Posted 13 Dec 2009 What about Reliance Scada? www.reliance.cz Share this post Link to post Share on other sites
Posted 11 Apr 2013 Yeah, it looks like Reliance SCADA/HMI can do it all and even a lot more than that! Share this post Link to post Share on other sites
Posted 12 Jul 2013 ...just noticed there's a pretty good Reliance SCADA leaflet, so you can quickly read about the main features & benefits: http://www.reliance-scada.com/files-to-download/Reliance4_Leaflet_2013_EN.pdf Share this post Link to post Share on other sites
Posted 10 May 2017 (edited) On 5/22/2009 at 6:06 PM, andyhill said: Looking for links to some simple SCADA What I need is a Scada Package or HMI package or some sort of OPC visualization to allow maybe max of 100 Points this needs to be ideally Freeware. or very cheap ware. Need to be able to communicate with OPC Server or Allen Bradley Controlllogix THis will only e used to display some PLC data for inhouse testing. I did try WINLOG LITE but it times out after about 10 mins - other wise it would have been perfect. We have full blown Wonderware for the main systems. but this means installing wonderware and servers etc I'm looking for something simple just to develop a few simple test tools graphics will be simple a few button and lights with some analog values. No need for security etc. ideally easy to set up on different machines in about 10 mins Dear Andy hill. I have small system with compactlogix to supervise 4 analog and 4 digital(start,stop). I tried to use Winlog SCADA. The first, I use WINLOG LITE, but i can't connect to rslinx opc server. I configured in RSlinx DDE/OPC Topic configuration and config in Winlog (OPC Client: Server node: my PC; OPC server: Rslinx OPC server and tried to create sample template; But i can't connect to data. Please giude me hot to do. Thank you so much Edited 10 May 2017 by huy doan wrong Share this post Link to post Share on other sites
Posted 18 Nov 2017 VTscada has a 50 tags free version. Share this post Link to post Share on other sites
Posted 23 January 3MM Bezel Windows Fanless Industrial Panel PC maybe a good choice for you. Features And Benefits: • 3mm Ultra-thin front bezel design. • Seamless panel design with IP65 dustproof and waterproof. • Whole Aluminum alloy enclosure, high efficiency for heat dissipation. • Sunlight readable and Resistive & Capacitive & Infrared touch screen option. • Versatile I/O supported: USB2.0/RS232/RJ-45/VGA/HDML.etc. • Wall-mounted, VESA, Embedded, Desktop stand installation option. • Integrated modules option:NFC/IC/RFID/MSR/Camera/LTE module...etc . More info at http://www.szjawest.cn/index.php/Content/Pagedis/shows_pro/catid/18/id/5.html Share this post Link to post Share on other sites
Posted 31 January Take a look to this, it supports OPC UA https://play.google.com/store/apps/details?id=com.suppanel.suppanel Share this post Link to post Share on other sites
Posted 31 January https://sourceforge.net/projects/advancedhmi/ AdvancedHMI is free. It is written in VB.net and runs on visual studio. Here is some information on the driver for Allen Bradley Controlllogi. http://advancedhmi.com/documentation/index.php?title=EthernetIPforCLXCom Regards, Garry 1 person likes this Share this post Link to post Share on other sites
