ahuat
Offset adjustment
Dear All, I am using CJ1W AD041 unit, and have some problem with offset, in manual W345-E1-05 i found the way to do an adjustment by using handheld programmer which i don't have now and it seems complicated. Does anybody has information how to do it by CX programmer? Thanks in advance. ahuat
Did you have a look at the unit's parameters setup in the IO Table?
My mistake, I missed the part where you mentioned offset To be honest, never had to do that. But if I have a quick glance at the manual: You can follow the procedures as described per manual section 5-7, but instead of entering the data with the handheld, I suggest you enter the CIO words to modify in the watch list of CX-Programmer. To make it easier, you could add the boolean symbols to the symbol list so you can identify them easily in the watch list. Alternatively, you can assign a keyboard combination to the PLC:Set on / Set off commands, to quickly turn the bits on or off when adjusting the offsets. It will probably require some practice though...
