scaver
[cx supervisor] how can i read output?
3 posts in this topic
Hi, I'm playing with cx supervisor. But I can't read an output. I can write an output to make a point: point type: boolean i/o type: output i/o refresh: on change i/o attributes: PLC type: CPM1(CPM1A) -CPU30 Data location: 10.00 Modifer: Force set/reset Communication enabled Data Transfer Action when opening a plc: write value to PLC ----------------------------------------------- How can I read an output? I thougt it would be someting like this: point type: boolean i/o type: output i/o refresh: on change i/o attributes: PLC type: CPM1(CPM1A) -CPU30 Data location: 10.00 Modifer: None Communication enabled Data Transfer Action when opening a plc: read value from PLC --------------------------- I guess this doesn't work.. How can I display the output? Is there a good example (script)? Tnx Ruud
Change your I/O Type to Input/Output. Input is for Read Output is for Write Input/Output is for both
Tnx.. I thought I wouldn't work, but this was because the script wasn't good.. Now it's fine!!! Greetz..
