Posted 10 Jun 2002 Hey guy, I'm currently writing an application to read/write the WORD in CS1G (CPU43) Omron PLC control through RS232 and I'm having some problem in the communication message format. I knew that to access the IR/HR/DM, I can use the following format: Read @00RR[Address][#Channel][FCS]* @00RH[Address][#Channel][FCS]* @00RD[Address][#Channel][FCS]* Write @00WR[Address][#Channel][FCS]* @00WH[Address][#Channel][FCS]* @00WD[Address][#Channel][FCS]* But i can get any information about the 'WORD' :-3 Hope, someone can help... Also, does anyone know where can i download the eveluation of the CX-Programmer/Cx-Simulator? regards, K-PAX Share this post Link to post Share on other sites
Posted 10 Jun 2002 Write @00WR[Address][Word][FCS]* @00WH[Address][Word][FCS]* @00WD[Address][Wordl][FCS]* Where 16 bit word is a four digit Hex value from 0000 to FFFF. The Hex Value 0001 is the first bit on in the word. The Hex Value 0002 is the second bit on in the word. The Hex Value 000F is the first four bits on in the word. The Hex Value FFFF is all bits on in the word. Regarding CX Programmer, you can download here. http://www.iespana.es/automat....ron.htm Regarding CX Simulator: I do not know of a CX Simulator demo. Share this post Link to post Share on other sites
Posted 14 Jun 2002 Hi k: First: test with syswin if you cable is ok and the correct number unit (@UU) Second: For read DM0010 to DM0015 you need to send @00RD00100005FCS*(ENTER) 00 number unit RD read data memory 0010 chanel initial 0005 number of chanels FCS checksum *(ENTER) termination you can find information on manual of programmation: command host link Share this post Link to post Share on other sites
Posted 31 Oct 2004 I can't links to :http://www.iespana.es/automatizacion/Descargas_Omron/descargas_omron.htm. Please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! thanks Share this post Link to post Share on other sites
Posted 31 Oct 2004 wrong address, try this one http://www.infoplc.org/Descargas/Descargas...argas-Omron.htm Share this post Link to post Share on other sites
