Guest Guest_LinuxGuy
Reading/Writing TAGS
5 posts in this topic
i want to Be able to read and write RS-View Tag Values thru Either RS-Linx or Rs_view, by ad external VB Application, cn anyone post Some VB code to do so >?
Either Would be Fine as long as i can have a stand alone VB app Accessing the Rs-View project either thru Rsview or Rs-Linx,,
Here one I started with DDE. http://forums.mrplc.com/index.php?&act=Down...&CODE=02&id=120 I finished all the DDE stuff to VB 6.0. But I never finished the data I got out of the PLC into an Access Database. Rich Schimdt did a DDE to Access application here: http://forums.mrplc.com/index.php?&act=Down...&CODE=02&id=137 I was going to see what he did and try and finish my project, but just haven't had time yet. The DDE part of my project works.
Are the RSView tags memory or device tags? If they're device tags, you can access them either through RSLinx or RSView. If they're memory tags, you have to go through RSView. Read the respective help files for the topic and item formats for each.
