ElctriclCncepts
Having trouble installing the CX-> Supervisor...
2 posts in this topic
The install is asking for a second disc from there I'm lost.... does this require a disc? I would think not.
Point the file path toward a valid CX Server install directory. If you have a CX Programmer install, it can be found under Disc 1 directory. Also if you are trying to run the install in a multi-layered hierchal directory, you may need to move the install software to a directory nearer the root directory on your computer. The necessary files are there if you are trying to run the CX Supervisor demo found in the Omron download section.
