All Activity
This stream auto-updates
  1. Today
  2. Help - I know so little, don't even where to post this! - But I am trying to fix my problem on my own!  I have an Omron Sysmac C20k in a machine that used to work until the board battery went dead.  I installed a new battery.  I have the mnemonic code that the machine uses.  My internet research says… If I buy:  A Hand held Console C200H-PRO27-E, A Hand held Adapter 3G2A5-AP003 A Hand held Cable C200H-CN222 – I should be able to input the code myself following the SYSMAC C20K Controller User Manual. - - Am I missing something? Anything??? Thanks you Guys!
  3. Help - I know so little, don't even where to post this! - But I am trying to fix my problem on my own!  I have an Omron Sysmac C20k in a machine that used to work until the board battery went dead.  I installed a new battery.  I have the mnemonic code that the machine uses.  My internet research says… If I buy:  A Hand held Console C200H-PRO27-E, A Hand held Adapter 3G2A5-AP003 A Hand held Cable C200H-CN222 – I should be able to input the code myself following the SYSMAC C20K Controller User Manual. - - Am I missing something? Anything??? Thanks you Guys!
  4. Yesterday
  5. Modbus TCP
    I would make it precisely to fit my needs.  Maybe Mitsu has something built-in, but I'm not a Mitsu expert.
  6. Tracking,
    Hello Guys! I would like to ask your help. I have a conveyor. At the begining of the conveyor i have a sensor which is declare wether a product is good or not. After that 5 meters i have to store out the bad product. In the exact place i have to stop the cv and store out. I have an encoder on the cv so i can calculate the correct position. The only problem is i have to write a tracking because i cant know when will the next wrong product coming. I could make some calculation making couple hundred rungs but its not sounds workable. Thanks ahead for any help.
  7. Modbus TCP
    I can't find the document in the e-manual
  8. STL Programming FXGP vs GXdeveloper
    Not that i am aware of. Also GX Developer is not supported anymore
  9. Modbus TCP
    Have a look op PAGE ID : SH081257ENG-8C2 of the e-manual viewer. Checking the simple CPU communication status.
  10. STL Programming FXGP vs GXdeveloper
    Gambit, Thank you. Is that option available in GX Developer?  Do you have part of a program that you can show in GX works?
  11. STL Programming FXGP vs GXdeveloper
    Upgrade from GX Developer to GX Works and under option in GX Works 2. Set Display STL instruction in contact format
  12. Modbus TCP
    Does the heartbeat function have to be created manually? Or is there a separate library from Mitsubishi Electric?
  13. Modbus TCP
      That's right, I want to know the communication status of the master PLC with PLC 1,2,3. is that possible?
  14. STL Programming FXGP vs GXdeveloper
    I haven't done any programming using SFC. Is anyone used GX works 2 for STL? Does it display the STL's with an "indent:?
  15. STL Programming FXGP vs GXdeveloper
    If you are going to Cange you might aswell change to GX Works 2 which still support the FX series up to FX3. As for STL is was a languge to do SFC. GX Developer and GX Works 2 both support SFC. Have you looked at this ?
  16. I have been using FXGP for programming our PLC's and have been using STL's for my ladders. We are looking to switch to GXdeveloper because FXGP doesn't work with newer versions of windows. I prefer the way FXGP "indents" the STL steps where GXdeveloper does not. I find the indented format much easier to follow. Does anyone have a way to display the STL's in the same format in GXdeveloper or is there something else I can use. I have included a part of a program using both softwares for comparison.     FXGP.pdf GXdeveloper.pdf
  17. Modbus TCP
    Since the master PLC is actually a modbus slave, and you want that slave to also respond to your monitoring, you will likely need to write a regularly changing value from each slave PLC to separate registers in the master PLC (heartbeat signals).  Then have code in the master PLC that will time out if a given slave's heartbeat stops changing.  Place the booleans for that status in other modbus addresses that the monitoring system can see.  (Or, perhaps, have the monitoring system watch the same heartbeat values.)
  18. Share more details.  What is the network topology?  Are both PLCs Allen-Bradley?  Are you using message instructions in one to talk to the other? If so, show the three tabs of a message configuration. Embedded service error indicates that a request used message router service 0x0A to embed multiple requests in a single packet, and one or more of those inner requests failed in the target device.  You would have to inspect the nested responses to determine the true error or errors.  (Wireshark will help you do that.)
  19. Wrong values on FX3U
    Check the How to use 2-phase 2-counting input counters C251 to C255 for 4-edge counting in the FXCPU Structured Programming Manual. It has to be continious on for the X00- X07 inputs to be used for counting, When it is not on the couter is off
  20. Wrong values on FX3U
    Does the OUT_C_32 has to be used once with a pulse signal? Or continuous? Still wondering why D8340 seems to have a bug... does anyone know why?
  21. Modbus TCP
    Look like you have all the communication running right ? So you question is where you can find the status of simple PLC comms ?
  22. I am a newbie when it comes to Ethernet/IP communication and Allen Bradley PLC setup. I have written a program in PLC to communicate with my device over Ethernet/IP communication. Communication is work fine for 1-2 hours, but later class 3 communication stops.  I captured wireshark log to debug the error. But on wireshark, I see the communication between IP address of PLC and PC port only. There is no device IP captured in wireshark.  My first question is - Is there any setting in PLC and wiresahrk to capture class 3 packets? Also, in wireshark, I see error packets "Embedded service error" when I connect two devices in line topology. When checked on Studio5000, Module shows ring fault status.  I am not sure why it took as ring topology, while my device is connected in line topology. I am not able to change it from ring to any other topology.  Can someone guide me here, how can I remove this ring fault? and what does this "Embedded service error" means? Thanks in advance!!!
  23. Modbus TCP
    Good day all, i need advice for Modbus TCP configuration on mitsubishi iQ-R PLC. I have 4 PLC iQ-R R08P CPUs with the configuration as shown in the picture. PLC 1,2,3 communicate with the master PLC using simple CPU Read/Write communication. from the master PLC, all tags on PLC 1,2,3 are configured to be modbus TCP with the RJ71EN71 module. The problem I am facing is how do I get the communication status of each PLC to the master PLC with simple CPU communication. I want to display the communication results of each PLC as a tag on modbus TCP. Thank you very much
  24. Last week
  25. Arithmetic behavior causing a quick zero
    The instruction is explained on page JY997D55801-2EA of the e-manual viewer.   LabelExampl.gx3
  26. Arithmetic behavior causing a quick zero
    Ther is no code attached, However I'll make a quick example of the ladder code from the previous mail in label style.
  27. Arithmetic behavior causing a quick zero
    Good morning. You did find it but the element dimensionis only 1. It should be 2. Also there is a easy way to cretae the correct label type. When using the instrcution just type an unknown vaiable name. Then it will prompt for a label declaration and the right type is alreayd pre selected.
  28. Omron NA5-NX1P2 - Password page
    Aah, I see now. So, I created a button labelled "LOG IN" and set the event as a "Click" and action as "Login()", so the Supervisor can change some parameters with his Level 5 access. And I created a "Log Out" button with the action set to "Logout()" for when he's done.  Thanks for the help guys! Much Appreciated.
  29. Load more activity
