All Activity
This stream auto-updates
- Past Hour
Joe E. liked a post in a topic: Ethernet/IP communication with Allen Bradley PLC in network
pturmel liked a post in a topic: The Integration of PowerFlex Drives in a Schneider Control System
If you have to track in arrays of larger data structures, using ring buffer techniques can greatly reduce CPU utilization. Using the shift instructions, or COP for shifting, is quite expensive. Instead of shifting, you add to an integer subscript for the load point to manage where you are in the array. And wrap around the end. For physical items on the conveyor a known distance downstream from your load sensor, you simply add to the load point subscript the constant for the distance (in array elements), wrapping it around, too.
- Today
BobLfoot replied to Asrarmeryem's topic in Modicon / Telemecanique / Schneider Electric
I doubt this will be much help, but AB drives usually have a Status Word, Command Word and Data Links between themselves and the PLC. The Powerflex Manuals will describe the Status Word, Command Word and Data Links in detail. The trick will be to find how in Schneider Memory / Tag Structure the EDS has mapped them. The HIM of the drives will also be useful as they will tell you when you have supplied th appropriate Stop/Enable signals to allow the drives to runa t all. Speaking of which, have you run the drives from the HIM to confirm you're enables and stops are wired correctly?- 1 reply
1
I've done this with covneyors and no encoder just a once per revolution of the driven shaft prox. So 5 meters might become 500 or 5000 pusles of the sensor. Then create an array of length 600 or 6000. I was usually using DINTS because I had to track more than just good/bad. Each prox pulse I check the bad sensor and load position 6000 of the array with a 1 or zero, After that I COP Array[1] Array[0] moving everything one position. A little trail and error tells me that due to rounding errors and such the unload/stop position is actually 98 or 997 not the 10 or 100 I calculated. Hope this napkin description makes sense. I'm sure it can also be adapted to using the encoder values.
pturmel replied to Deeksha's topic in Allen Bradley / Rockwell Automation
No question about that at all. But I am often not on-site, so a port mirror that can be configured remotely has great value. And, sometimes, simply moving connectors masks a problem. -
Karlmk joined the community
VjiupsCor joined the community
Steel Rate Today joined the community
VFD Guy replied to Deeksha's topic in Allen Bradley / Rockwell Automation
Port mirroring is complicated. Either find an old hub or use a sniffer is the easiest. I use shark tap. -
VFD Guy started following Ethernet/IP communication with Allen Bradley PLC in network
Troubleshooting problems in cases like this. Most modern managed switches have features to help technical staff connect wireshark to specific ports, so that sources of bad behavior can be examined unfiltered, and without relying on an intermediate two-port switch. Actual DLR, though, is awesome. - Yesterday
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this and are unable to assist.
BobB started following SMS messaging from a CJ2M-CPU31
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it says that for main power, 1ph 240VAC for rated current of 6.5A, and for controller power, 1ph 250VAC with rated current of 0.2A. will it be ok to use 6.5A fuse for main power and 0.2A fuse for controller power? or what calculation or table do I need to use to select proper fuses? Thanks,
thank you, my problem has been resolved
So, some more details. The BSL and BSR instructions operate on a rising edge of the rung enable. You would enable the instruction once every time the encoder turns enough for a part to have passed by. The last one I did is in a CompactLogix. I had to create a tag called "Track_Array" of type DINT[1]. The Array tag of the BSL instruction was Track_Array[0]. Its Control tag is a new otherwise unused tag and the source bit (for me) is an Always_Off bit. Length is the number of parts that can be on the conveyor plus a few. If the conveyor is more than 32 parts long, you'll want to have your Track_Array tag bigger. For example, DINT[2] will get you 64 positions. The one I did was anchored at the load station being station 0 so I used a BSL. If instead you want the end to be bit 0, you'd use a BSR instead. Doesn't really affect things other than how you think of it. Here's the rung with the BSL. CAM_00 is on once per machine cycle. In your case, you'd flash it once every time a part spot has passed by on the conveyor: Here, we set bit 1, which is where the servo loads the blanks: Here, we clear bit 8, which is where the finished parts fall out of the machine. Like I said before, I'm not 100% sure this is really the best way to proceed for you. It may make more sense to use a FIFO array. Use an FFL instruction every time a part passes by the sensor and an FFU every time a part arrives at the end position. Downside to using a BSL/BSR is if the parts can slip on the conveyor. If that's not an issue, the FIFO won't work if parts can be removed from the conveyor between the sensor and end. That's why it's good to have multiple tools in your belt.
If all you want is to store good/bad, use a bit shift array using a BSL or BSR instruction. High level description: You'll execute the BSL/BSR once per "interval" of the conveyor's movement. Let's say the end position is at bit 0 of the array and the sensor is at bit 20. The sensor will set/reset bit 20 of the array while the reject/whatever sequence looks at bit 0. A BSR is fired to shift the data automatically.
ferrretcatcher started following How to open a .GRP ladder file?
I'm working on a retrofit controller for my Leadwell 550E VMC. The tool changer is different on this machine than what comes setup in the new 3000M controller, mine has a up down function for the umbrella style too changer. I outputted the ladder file from the new 3000M controller and it came out as Ladder01.GRP. Does anybody know what ladder program can open and edit this kind of file? I tried RSlogix and AD's do more designer and neither worked. I can open it with hex editor and it will display some of the I/O but cannot edit anyting meaningfully. The ladder is 1600 lines of code and i can possibly edit it at the machine, but i really don't want to work through that long of a program standing at the machine. LADDER01.GRP
Firstly, thank you for your answer! Secondly, yes they are the same size. Im trying to make the proper code for the task. I made in the first row, a signal when a bad product is detecting I raise a counter like 1, 2, 3 4. ... and so on. In the next row I check wether the counter is equal to 1 if yes, then I start to accumulate the pulses from the encoder until its reaches the 500, at that point I make a Stop signal, then I clear the counter. Of course there is a possibility, there is a new NG product can appear before the former one stored out, so if the Bad_product_appear bit is active again then the Counting counter isgoing to be 2 and it sarts to count also for the second, as the same way as before. My question is what if I have to make like 200 row like this, I think there is a better solution. Anybody can help this, if my explanation is poor Im sorry, I try to answer for every question. Thanks ahead.
Joe E. replied to Deeksha's topic in Allen Bradley / Rockwell Automation
I've seen many applications that used the dual ports in a daisy-chain configuration. Is the main drawback that all downstream devices go away if one in the middle is powered off? Or is there another reason too? -
Are the products all the same size? If so, I would first create an array big enough to have one position for each place a product could be on the conveyor. Array could be bits or integers, depending on how much info you want to track. Use the encoder to advance the array. Write to the right spot in the array at the sensor and read from it at the "store" position. That's my first pass thought.
I can tell you about a year ago I dealt with the same issue on a QPJ similar to that. it appeared that it was dead but you could hear it change screens and work still. The contrast was shot on it. someone somehow messed with the contrast. the best thing you can do is try to change it blind. I think pressing in the bottom corners of the screen at the same time will pop up the contrast adjustment, and you can pick a square at the bottom after that to change it. I probably have some pics here somewhere I can put up to give you an idea of what it looks like.
Trippled the number the panels we build a year. Looking into the cut, strip, ferrule crimp tools with the barrell chamber that holds a strip of ferrules and you just stick the stripped wire in and crimp. Looks like there are 3 popular versions. Phoenix Contact 1200101 Crimpfox 4 in 1, Weidmuller 9020000000 and Panduit CT-1000. Anyone have experiences with these or any other I may have missed? Recommendations?
Wireshark can only capture packets that arrive at the PC's physical network interface. That often requires using a special mode on your switch to "mirror" everything to the PC's port, and ensuring that all devices are connected to the switch. You will not be able to capture traffic from daisy-chained devices. (The dual ports on AB devices should only be used for real rings.) The mode problem suggests that the device in question is "owned" by something. What are these devices? Please also show your Studio 5000 I/O device tree where Device1 and Device2 are present. -
IO_Rack started following Input to C20K - Trying to See if I can do this!
Your internet research is correct. The C20K is very old and has been obsolete for many years. The option you list could be expensive. Even if you got the PC adaptor, the software is so old you would have a difficult time getting it work on a PC. I would highly recommend getting a CP1L as a replacement.
Gambit started following Mitsubishi GX Works 2
You can download the latest version via your MyMitsubishi Account. V1.662 is the latest one i think
Deeksha replied to Deeksha's topic in Allen Bradley / Rockwell Automation
Also, for my device 2, where port 0 is connected to device 1 and port 1 is unused. But on studio 5000, I see both ports are checked with port 1 marked as inactive. I tried to uncheck the port 1, but it says that can't perform operation due to module mode. I don't understand how to fix this. snaps are attached. -
Thanks for the reply. My two devices are connected in line topology, Device 1's LAN port 1 is connected to router and LAN port 2 is connected to device 2. Then PLC is connected to router. router is connected to my PC. only one PLC and one EIP module, both are Allen Bradley. PLC - 1756-L81E and IO module - 1756-EN2TR. Yes, using msg instruction to talk to my both devices. snaps for three tabs are attached. On wireshark, I am able to see packets only for port between PC and router. How to inspect nested responses in wireshark? I tried to look into the packet, but couldn't decode. -
Hello I'm currently running GX Works 2 Version 1.60SF What is the latest Version? and how do I obtain Thanks Gary
gashman started following Mitsubishi GX Works 2
- Load more activity
